2001 Honda Prelude Overheats With A/C
YOUNGROYAL
I have a 01 Honda Prelude and as I'm driving with the A/C on the engine temperature seems to rise up forcing me to cut the A/C off? What should I do
Jun 22, 2007 at 10:26 AM
BRUCE HUNT
  • 3,754 POSTS
First is check the coolant level of the engine. That is the radiator and the overflow container. If that is full, you might consider replacing the thermostat but make sure that the radiator fan on the cooling system is functioning. The one on the radiator for the A/C should come on as soon as the A/C is activated.
Jun 24, 2007 at 4:48 AM
Suggested Repair
Check the radiator and overflow coolant levels. Confirm the radiator cooling fan works and that the A/C fan comes on as soon as the A/C is activated. If the coolant is full, consider replacing the thermostat after verifying fan operation.
Conversation Summary
The owner of a 2001 Honda Prelude reports that engine temperature rises while driving with the A/C on, requiring the A/C to be turned off. The expert advises checking coolant in the radiator and overflow container, confirming the cooling fan works, verifying the A/C fan comes on when the A/C is activated, and considering thermostat replacement if the coolant is full.
