1990 Honda Prelude Overheating
LUDEDUDE
  • 10 POSTS
1990 Honda Prelude, 2.1 motor, 136K miles.
I'm having a major overheating problem with my Lude. I recently replaced the cylinder head, timing belt, and water pump. The car ran good for about 1,200 miles. I started to smell anti freeze frequently while driving but couldn't figure out where it was coming from. There would be pressure in the system just from sitting overnight. The upper rad hose was bugged out. I removed the radiator cap, motor not running, and the coolent flew all over the engine compartment. A few days ago the car overheated in my driveway while at idle. Coolent was being forced out of the overflow container. I changed the rad cap and bled the cooling system. Idle was fine and the car ran good but gradually pressure built up and forced coolent out the overflow again and my rad hose was bugged out. Took a compression test and am not a happy camper. No. 1 cyl. 155 lbs. No. 2 cyl. 180 lbs No. 3 cyl. 200 lbs. No. 4 cyl. 170 lbs. There is no water in my oil and do not see any oil in my coolent.
Changed the distruibutor and set up timing.
Anyone have an idea what may be causing this problem? Any help is appreciated.
Thanks,
ludedude
Apr 24, 2007 at 2:44 PM
  • 75,988 POSTS
[quote:1f44dfd3a9="ludedude"]1990 Honda Prelude, 2.1 motor, 136K miles.
Thanks,
ludedude[/quote:1f44dfd3a9]
Try replacing the thermostat-not it do the following below:
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: Thermostat,Clogged radiator,Fan clutch,Radiator electrical fan,collasped hoses,water pump.
Apr 25, 2007 at 12:20 AM
LUDEDUDE
  • 10 POSTS
I don't suspect the water pump since it is a new one. The rad hoses are good and electric fans both work. I'll change the thermostat again and have the rad checked out. Will have to tow it to a shop for the block and pressure test first though.
Thanks for the reply.
Apr 25, 2007 at 1:24 AM
Suggested Repair
Replace the thermostat, then have the block tested first—or use a gas analyzer at the radiator neck—to check for combustion gases entering the cooling system before any cooling-system pressure test. If those tests pass, inspect the radiator for clogging and recheck the fans, hoses, and water pump.
Conversation Summary
A 1990 Honda Prelude with a recently replaced cylinder head, timing belt, and water pump developed coolant pressure even when sitting, swollen radiator hoses, coolant forced from the overflow, and overheating at idle. Compression varied by cylinder and there was no oil-coolant mixing. The expert recommended a thermostat replacement and a block test or hydrocarbon sniff before a pressure test, then checking the radiator, fans, hoses, and water pump if those tests pass. The owner planned to replace the thermostat, have the radiator checked, and tow the car for testing.
