HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Honda
Prelude
Engine
Symptoms
Overheat
1989 Honda Prelude Overheating
TREABRAHAM
MEMBER
1989 HONDA PRELUDE
4 CYL
AWD
AUTOMATIC
299,999 MILES
My car is overheating and the heater stopped working right when that happened could it be my thermastat?
Sunday, November 16th, 2008 AT 1:30 PM
KHLOW2008
MECHANIC
Hi treabraham,
Check the coolant level in radiator. If it is low, engine would overheat with loss of heater operations.
If level is low, you need to check/test for coolant leakages and rectify accordingly.
SPONSORED LINKS
Thursday, November 27th, 2008 AT 3:40 PM
Please
login
or
register
to post a reply.
Related Engine Overheat Content
1992 Honda Prelude Car Over Heating
I Have A 92 Prelude With An H23a1 For The Motor And It Overheats After 45 Min Of Driving. I Changed The Thermostat But It Still Over Heats...
Asked by
*justinv*
1 ANSWER
1992
HONDA PRELUDE
VIDEO
Is Your Engine Cool Enough to Check?
Instructional repair video
GUIDE
Overheating Symptoms
An overheating engine is never a good thing to have happen. If the problem is caught quickly you can save the headache of a major engine repair. Knowing the information from...
It Only Overheats When I Come To A Stop
99 Honda Prelude Overheating: If I Remove Prelude Thermostat Would That Fix My Problem? I Would Replace It Down The Road. $$. When I Step...
Asked by
FONY67
1999
HONDA PRELUDE
Overheating Problem +
1990 Honda Prelude, 2.1 Motor, 136k Miles. I'm Having A Major Overheating Problem With My Lude. I Recently Replaced The Cylinder Head...
Asked by
ludedude
HONDA PRELUDE
Cant Start When Engine Is Hot
F22b Jdm 93 Honda Prelude When Engine Hot Cant Start Again Until The Check Engine Light Is Off! It Takes About 10 To 15mins For The Warning...
Asked by
peter ohara
1 ANSWER
1 IMAGE
1993
HONDA PRELUDE
Overheating
Can A Idle Control Valve Put Or Get Air In My Coolant System?
Asked by
life
1 ANSWER
1992
HONDA PRELUDE
VIEW MORE
SPONSORED LINKS
Cooling System Pressure Test
Online car repair manuals
