2001 Honda Prelude No Air From Vents
ANIJHA
i have a honda prelude 2001 with 75000 miles on it.i got new stereo system installed in my car and ever since my climate control system is not working. there is no air coming out the air vent at all even though i slide it all the way to right. when i turn on my a/c and i am driving on freeway, i can feel a bit cold air air come in so i know my a/c is fine. but there is no air coming out of the vent. i checked all my fuses and they r fine. so i don't know what to do. please help me out
May 17, 2006 at 7:21 PM
BRUCE HUNT
  • 3,754 POSTS
It seems that quite a number of people are experiencing problems with other components in their vehicle after installation of a new stereo. First off, if you do the work yourself, using an approved wiring conversion kit is a must. Wiring directly to other power sources or fused circuits can cause problems. If the car experiences problems right after installation by a professional, take the car back and demand the job be done right and explain the problem. Caution: just because the company installs other stereos does not mean that they are right for your job. Find out more about the installing company. Often new stereos are a lot more than just a new radio system, they include amplifiers and amplified speakers with wiring being hooked to various power sources. If you experience problems, why not try undoing what you did and see if the problems disappear. Exercise caution when installing any electrical device in your car.
May 23, 2006 at 8:57 AM
MACAT
  • 17 POSTS
sounds like a heater/ac controller to me ceck it out.
Jun 6, 2006 at 4:21 AM
Suggested Repair
Because the climate system failed right after the stereo install, have the installer recheck the wiring or undo the stereo work to see if airflow returns. Use an approved wiring harness rather than tapping other power or fused circuits. Also inspect the heater/AC controller if the problem remains.
Conversation Summary
A 2001 Honda Prelude with 75,000 miles has no air from the vents after a new stereo was installed, although some cold air is felt while driving with the A/C on and the fuses check out. The expert says stereo wiring or power connections often cause other electrical problems and recommends a proper conversion harness, returning the car to the installer, or undoing the install to test. Another reply suggests checking the heater/AC controller.
