1993 Prelude A/C??
1993 ALL OTHER MAKES ALL OTHER MODELS
JAMES_JARVIS19
I have a squealing noise when i start my car cold, and it usually last 2-3 minutes. Seems to cut in again if i turn the a/c on, and cut out when i turn it off!! What could this be, why, and how do i fix it?
May 10, 2007 at 12:06 PM
BOOTDOG
  • 665 POSTS
more than likely it's the belt. take some lubricant like wd-40 and when you first start the vehicle, spray it on the belt. if the noise goes right away, then replace the belt.
May 10, 2007 at 1:08 PM
JAMES_JARVIS19
Nope, it's not the belt, belive me i've tried the wd-40, belt dressing, everything i recently done an engine swap too and replaced all the belts so everything has less than 1000km's on it!!
May 10, 2007 at 3:43 PM
BOOTDOG
  • 665 POSTS
check to make sure the ac compressor isn't locking up when the clutch is engaged. also check all other pulleys too.
May 10, 2007 at 10:11 PM
