New Radiator installed now air cond blows hot?
SHAWN99
Prelude 1998 - 194,000 v-tec 2.2 engine. I replaced my radiator today and when i was finished everything worked great but now my super cold air conditioning that worked great until now is blowing hot air. The compressor is turning but only blowing hot. What could I have done ?
Oct 23, 2007 at 2:11 PM
BLACKOP555
  • 10,386 POSTS
did you discharge the ac system?
Oct 23, 2007 at 3:11 PM
SHAWN99
I did not knowingly discharge system. There is a electrical plug coming out of the air conditioner compressor that plugs into the side of one of the two cooling fans attatched to the radiator but this was my only contact with the air conditioner that I'm aware of.
Oct 23, 2007 at 11:29 PM
KENT MILLAR
  • 0 POST
Because it doesn't answer the question I replace my my radiator as well and now my AC is blowing warm Freon is good holding pressure and compressor is kicking on?
Dec 8, 2022 at 9:10 AM
  • 55,691 POSTS
Are the cooling fans coming on with the A/C? If not, I would make sure they are plugged in correctly and the ground for the fans are attached.
Dec 10, 2022 at 5:21 AM
