'93 Honda Prelude Si A/C Problems
TAANZAA40
Hi:
I've been experiencing some trouble with my A/C. I have a '93 Honda Prelude Si (has 280,000, 5MT, 2whl dr).
Normally my A/C works great. But, at the beginning of the warm season I noticed it was cooling as efficiently as before. I assumed (because of it's age) it probably needed a shot of r134a. I had the system evacuated and recharged. However, I am having trouble with the A/C blowing cold, then hot; cold, then hot.
First fix: mechanic suggested the compressor was shutting off prematurely and was caused by a thermal pressure switch located on the compressor. That was replaced and I'm still experiencing the same problem.
Second fix: mechanic suggested changing the expansion valve as he said the high pressure side was shutting off the compressor at around 100 psi instead of at the limit of 200 psi. So, the expansion valve was changed. *note: I couldn't find a receiver/drier to fit that day so, he put my old receiver/drier back on.*
The mechanic also said he thought there was too much oil in the system and took some out (?). He also said that he was putting dye in the system to see if there were any leaks.
I then had a problem with a leaking oil cooler hose that was causing my car to overheat. I had the two hoses replaced and noticed a difference in the performance of the A/C for about 2 weeks (don't know what the relation is).
Now, I'm starting to have the same problem again. Cold air, then hot air, then cold air then hot air.
I don't know if this helps any but, I have noticed that my car does seem to heat up more quickly in the morning (the hoopty is usually fairly cold natured and takes a minute or two to get going) When the A/C was working correctly the past two weeks I noticed the fans seemed to never shut off and it seemed to be causing a constant load on the engine. Now that the A/C is back to the cold/hot action the engine seems to be performing as usual.
My mechanic suggests changing the evaporator.
Could you give me some suggestions and perhaps an explanation as to why he would think the evaporator is bad?
Thanks for your advice!
Jun 27, 2007 at 5:16 AM
2CARPRO JACK
  • 11,533 POSTS
Not sure why he would think the evaporator is bad. The fans should come on when the a/c is turned on.Does the compressor turn off and on when this problem is occuring? If your car is running hot, it changes the pressure and thus the performance of the a/c system.
Jun 28, 2007 at 1:38 AM
TAANZAA40
When the A/C starts blowing hot the compressor is off. I spoke with my mechanic and asked why he thought the evaporator was bad and he said he did notice some dye from the refrigerant coming from the area of the evaporator when he changed the oil cooler hoses.
The car no longer runs hot after the hoses were changed. I'm supposed to take it back to him today so that he can check and see if he sees any leak from the evaporator today. I'll post with the results.
Is this not a normal occurrence?
Jun 28, 2007 at 4:51 AM
2CARPRO JACK
  • 11,533 POSTS
Sometimes older a/c systems can be like an old tire, repair one leak and the increased pressure causes another one
Jun 29, 2007 at 12:55 AM
TAANZAA40
Well, when I took it to the shop yesterday, because they had seen dye and antifreeze mixed when they changed the oil cooler hoses, it appeared the refrigerant leak was coming from the evaporator. Now, he informed me to first change a pipe (suction pipe where the high/low pressure fittings are located). He said that after cleaning up the leaked antifreeze and refrigerant dye this is where the leak appears to be coming from. So, I've just ordered that and we'll see what happens. :?
__________________________________________
[quote:958cdb1960="2CarPro Jack"]Sometimes older a/c systems can be like an old tire, repair one leak and the increased pressure causes another one[/quote:958cdb1960]
Jun 29, 2007 at 4:18 AM
2CARPRO JACK
  • 11,533 POSTS
let us know.
Jun 30, 2007 at 1:24 AM
TAANZAA40
I'll make sure to keep everyone posted on the progress.
__________________________________________[quote:cce7304be6="2CarPro Jack"]let us know.[/quote:cce7304be6]
Jun 30, 2007 at 3:53 AM
