1996 Honda Prelude Blinking light and not blowing cold
168,000 MILES • 4 CYL • FWD • AUTOMATIC
CCSSL
I was driving and my ac just randomly stopped working, the ac had always blown really cold. A blinking orange light started with the ac problem, I'm not sure if the light is the rear defroster or if it is the heater. However, whenever I attempt to turn the ac on the blinking light comes on, when I turn off the ac the blinking light turns off. I have tried recharging my ac with R-134a to no avail, the gauge read a really high pressure yet nothing changed other than the blinking light turned off while the ac was turned on for about a minute, maybe less. I found a wire that connects to one of the fans that was rubbed through so I spliced it and that didn't fix anything either. I have no idea why the ac would stop working unless it was that one broken wire which I fixed. I think if that was the case maybe it blew a fuse, however, I cannot find a fuse in either of the fuse boxes that says ac. Do you have any ideas on what could be the problem? Or What fuses relate to the ac unit? I have found a lot of forums in which people have had problems with the ac control unit needing to be re-soldered, could that account for any of the problems I'm having?
Sep 3, 2010 at 9:19 AM
KHLOW2008
  • 41,812 POSTS
Hi ccssl,
Is it the A/C system that is not cold or the blower fan stops blowing?
Sep 7, 2010 at 1:35 AM
CCSSL
It is the ac system that is no longer cold... The blower fan still works just fine.
Sep 22, 2010 at 5:34 AM
KHLOW2008
  • 41,812 POSTS
When A/C is not blowing cold, check if the compressor is engaging or cycling on and off.
Note if the cooling fans are working.
As to the Orange blinking light, which is it? A picture of the component would help.
Sep 23, 2010 at 2:14 AM
