2001 Honda Prelude clutch
HELPAHONDA
  • 2001 HONDA PRELUDE
Shakes or Wobbles problem
2001 Honda Prelude 4 cyl Front Wheel Drive Manual 81xxx miles
well I believe my clutch is shot but im not 100 percent shure. When I slowely let off the clutch its almost like my car has wheel hop I believe its engaging too hard
Friday, March 12th, 2010 AT 1:38 PM
KHLOW2008
  • 41,814 POSTS
Hi Helpahonda,
Juddering at slow take off are usually caused by contamination to the clutch disc. There is a possibility some oil has gotten onto the disc surface.
If clutches are worn, it wuould slip when accelerating hard.
Monday, March 15th, 2010 AT 11:10 AM
HELPAHONDA
Yea thats excitally whats happening. When I accelerate it doesnt slip but how can I fix this problem. Thanks for your help
Tuesday, March 16th, 2010 AT 3:36 PM
KHLOW2008
  • 41,814 POSTS
Rectification is by replacement of the clutch assy and cleaning/refacing the flywheel.
Sometimes the problem recurrs even after replacement of the clutch assy, mostly with non OEM parts but OEM parts do have such problem as well.
You can either live it till the clutch weras off and then get it replaced or take the risk of the problem recurring and go ahead with replacement of the cluth.
If there is any oil leakages from the transmission or engie, those should be rectified first as oil getting onto the clutch disc are possible causes of the juddering that you are encountering.
Wednesday, March 17th, 2010 AT 7:07 AM
