I am constantly having to add clutch fluid. I can't see where any is leaking.
Thursday, November 20th, 2008 AT 7:39 PM
KHLOW2008
MECHANIC
Hi Nelson,
The common places for leakages are
1. Slave cylinder, pull the dust cover and see if any fluids are inside.
2. Master cylinder. You need to get under the dash to look at the master cylinder and if it leaks, the fluid would get into the vehicle, thus no noticeable leakages.
SPONSORED LINKS
Thursday, November 27th, 2008 AT 3:43 PM
RODGER CHASE
MEMBER
Sounds like the seals are bad, yes replace the master cylinder. Don't know if that is the right name, the part that the clutch pedal connects to. Had the same issue with my Toyota, you wont see it. But most likely yes that is it.
Friday, March 13th, 2020 AT 5:33 PM
MECHANIC
Thanks for the addition to the site. This post was from over 10 years ago so I doubt that helped them but I am sure that info will help others that may have the same issue.
Let us know if there is anything we can ever help you with. Thanks
