My clutch just fall back it don't pop back out. When my clutch is push back I can still start my car it just the clutch don't pop back up pls help?
Oct 29, 2009 at 8:30 AM
✓Experienced Mechanic
Hi there,
You will need to check the slave cly at the gear box and the master cly for fluid leaks, look under the dash where the pedal rod comes through the fire wall and under the rubber boot at the slave, any fluid is a leak and you will have air in the line, replace the faulty component and re bleed the system.
