1999 Honda Prelude Intermittent Clutch Issue
163,000 MILES • 4 CYL • FWD • MANUAL
RAMCCOY
The clutch intermittently acts up in such a way that while idling in neutral with the clutch to the floor, I cannot shift into any gear. If I shut the engine off, I can shift into any gear, but if I start the engine, the vehicle idles very roughly and attempts to lunge forward. Most of the time I can shut it off, wait a few minutes, restart the car and it will then shift OK.
This only happens in parking lots or at stops. (Low Speed). I have never have had an issue when driving down the road.
Aug 10, 2009 at 2:47 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Have tried bleeding system ? air maybe in there or clutch master has a piston seal leak allowing pressure to bleed off. Try pumping pedal see if that allows shifting. if so then master or slave is faulty.
Hope this helps
Thanks for donate
Aug 10, 2009 at 3:12 AM
RAMCCOY
I havenot bled the clutch system. Pumping the clutch does not help. So far the only thing that seems to help is to shut the car off wait a few minutes, then restart. The issue doesn't seem to be related to the car being hot or cold.
Aug 10, 2009 at 4:45 AM
DOCFIXIT
  • 18,828 POSTS
Well before replacing parts do the bleed first see if air is problem
Aug 10, 2009 at 4:50 AM
RAMCCOY
Where is the bleed valves located and what is the proper sequence for bleeding?
Aug 12, 2009 at 6:33 AM
DOCFIXIT
  • 18,828 POSTS
Bleeder on slave cylinder on transaxle. Attach tube to bleeder place other end in container of brake fluid. Open bleeder pump until no bubbles are present.
Aug 12, 2009 at 6:51 AM
