1997 Honda Passport Stumbles Under Load
CASTFE
I have a '97 Honda Pasport, 122,000 Miles, 3.2L V6 Engine, Automatic Transmission, 4WD.
I have been working for the past several weeks on this vehicle trying to solve a problem with the engine "Cutting Out / Stumbling" under load. The vehicle will idle normally and rev up with no hesitation under no load, but if you are accelerating from a stop the engine will cut out and in creating a sort of jerking sensation. If you accelerate verry slowly however there is no problem, and once you get moving you can drive at any speed and accelerate normally.
I took this car to a shop and they told me that it needed an Ignigition control module, and that this part was no longer available and they could not fix the vehicle. I drove the car home (very slowly accelerating the whole way) and parked it in untill I found an ignigtion control module at a Junk Yard (This module has been discontinued by the manufacture, and is not available new). I replaced this part, and the problem is exactly the same. I therfore assume that the $300.00 I spent for the repair shop to diagose the problem was a waste of money unless the 2 ICM's have the exact same problem. (Not Likely in my opinion)
I have checked to see if any codes are present, and everything reads clear.
I have since replaced the Fuel Filter, spark plugs & MAP sensor, all with no effect.
I also Replacerd the PCV Valve while I was replacing the valve cover gaskets which were laeking like a sive.
I have also tried disconnecting diffrent sensors one at a time to get the car to go into "Limp Home Mode" and nothing has any effect on this problem, other than causing the Check Engine Light to come on untill I reconect the sensor and clear the codes. So far I have tried disconnecting the EGR Valve, TPS & MAF Sensor and nome of them seem to have any effect on the condition I am having. I have also looked / Lisetened for any Vacume leaks and havn't found anything.
I can duplicate this problem every time by just putting my foot on the brake and then stepping on the gas while the car is in drive. I also tried the same thing in reverse, and there is no problem, so I really don't know what to try next. I don't understand why the problem only occurs when the car is in drive.
Any help or advice you could give on this issue would be greatly appreciated.
Regards,
Michael N.C. Allen
Nov 27, 2006 at 8:30 AM
  • 55,676 POSTS
Lets check the air intake boot for cracks, and we need to check fuel pressure, possible fuel pump going out.
Nov 27, 2006 at 10:22 AM
EX19
[quote:0a1f71b7b1="CastFE"]Hello,
..If you accelerate verry slowly however there is no problem, and once you get moving you can drive at any speed and accelerate normally.[/quote:0a1f71b7b1]
We have the exact same issue on a 98 honda passport. We've tried tuning it up, replacing things, still there is a check engine light. Now they are saying change out the catalytic converter. We need to pass smog. Hate spending hundreds of dollars as we are not mechanics and must rely on others to do the work and keep it honest. We are in San Diego North, and really need to find an honest mechanic or dealer. Any clues?
Sep 1, 2007 at 7:36 AM
Suggested Repair
Inspect the air intake boot for cracks and check fuel pressure, since a failing fuel pump may cause the stumble under load.
Conversation Summary
A 1997 Honda Passport with a 3.2L V6 idles and revs normally but cuts out or jerks when accelerating from a stop under load; slow acceleration and driving once moving are fine. The owner replaced the ignition control module, fuel filter, spark plugs, MAP sensor, and PCV valve, found no codes or vacuum leaks, and disconnecting sensors did not change the symptom. An expert advised checking the intake boot for cracks and testing fuel pressure for a possible failing fuel pump. A later commenter reported a similar issue on a 1998 Passport and mentioned a catalytic converter recommendation, but no further expert diagnosis was given.
