1998 Honda Passport Hood Won't Open
RWALTER
I for some reason can not get my hood open. I have a 1998 Honda Passport. I tried pulling the release tab but nothing happens..... i need to get it open because my battery is dead.... please help!!! :x
Dec 7, 2006 at 1:02 AM
BRUCE HUNT
  • 3,754 POSTS
When you pull the hood release does it return to the normal position and do you feel any resistance? I am trying to determine if it is the latch or the cable? Your options are a little bit limited but the best means available is to raise the front of the vehicle to make it easier to work on and use car jack stands for safety. Remove the rubber/plastic shroud beneath the radiator. Now you get to reach with a tool to try and get the latch to release. Not fun and not easy.
Dec 7, 2006 at 1:44 AM
RWALTER
thank you very much!!! No I really dont feel any resisitance. But i did take the cover off and i can not get to the release the fan is in the way
Dec 7, 2006 at 3:15 AM
BRUCE HUNT
  • 3,754 POSTS
Another way to get in is by removing the grill. This is not easy but I know if they made it any easier vandals would get access.
Dec 7, 2006 at 3:59 AM
RWALTER
thank you for your time but i fixed it... i unscrewed the whole release and part of the cable was broke so thank you oh how hard is it to replace the cable for the hood latch...
Dec 7, 2006 at 1:27 PM
BRUCE HUNT
  • 3,754 POSTS
Not really too hard. You can use the cable when you pull the inside release off to pull a wire throught the firewall and hook the new one on to it to pull the new cable end through the firewall. Pretty straight forward and easy job. Good luck!
Dec 7, 2006 at 3:36 PM
Suggested Repair
Replace the broken hood-release cable. After removing the interior release, use the old cable or a pull wire to fish the new cable end through the firewall, then connect it to the latch.
Conversation Summary
The owner of a 1998 Honda Passport could not open the hood and felt no resistance when pulling the release, with a dead battery making access urgent. The expert suggested checking whether the cable or latch was at fault and reaching the latch from below or by removing the grille. The owner later found part of the cable broken at the release and asked about replacement. The expert said cable replacement is straightforward by using the old cable to pull a wire through the firewall and draw the new cable through.
