2002 Honda Civic Sputters Under Load
MDOYLE
  • 5 POSTS
I have a 2002 Civic Si, the chassis has approximately 90k on it, with a motor that is in the mid 40's. Recently my car started to expirience a sputter or backfire while holding speed on the freeway. I checked the plugs and they appeared to be fouled with oil, so I replaced them and got new valve cover gaskets to go along to change any chance of it happening again. It seemed to work, for about a week, but it came back. It has now gotten to the point where I don't want to drive the car, as I don't want to make the problem worse. It is also now doing it under acceleration, not just while cruising. I have exchanged the following parts from a known working car; coil packs, map sensor, fuel pump/filter, fuel injectors, fuel rail, throttle body, main relay 1 and 2, ECM and intake manifold has been cleaned, air filter is in good condition. There are no codes on the ECU. No cat-converter is on the car. Yet the problem persists. I do not know what else I can change to get it to go away.
May 8, 2006 at 4:34 AM
BRUCE HUNT
  • 3,754 POSTS
Replaced the plug wires? Have you had the timing checked as well? When you pulled out the fuel filter did you dump out the contents and note if any moisture was in the gas? Any your fluid levels dropping? Have you done a compression check? I would look at these items. They are reasonably inexpensive and can tell many tales about what is happening in the engine.
May 8, 2006 at 7:09 AM
MDOYLE
  • 5 POSTS
Coilpacks were changed with good units, compression test and leak down test were both done and nothing is out of spec. Timing is perfect. I didn't dump the contents of the old filter out, but did replace it so I don't see how that could be a problem. I have also checked for any loose connections and vacuum leaks.
May 8, 2006 at 8:08 AM
BRUCE HUNT
  • 3,754 POSTS
Reason I asked on the filter was for water in the system. Sometimes something so useful is so harmful. Water in the system can cause the symptoms. Wires, Wires, Wires. Simple stuff before the deep stuff.
May 8, 2006 at 2:29 PM
MDOYLE
  • 5 POSTS
The newer Honda's (the K series motor) do not have wires, they have coilpacks, which I have already changed, as stated in my previous posts.
I might try draining the tank then, it's nearly empty anyhow.
May 9, 2006 at 2:04 AM
BRUCE HUNT
  • 3,754 POSTS
Sorry I forgot about the newer engines and no wires. I have to keep kicking myself on that.
May 9, 2006 at 4:26 AM
MDOYLE
  • 5 POSTS
Thanks for the suggestions, i'll be draining the tank later today and putting in some high octane fuel to see if maybe there is something left in the lines.
May 9, 2006 at 4:50 AM
MDOYLE
  • 5 POSTS
Well, after another day of swapping parts we finally narrowed it down to a bad Primary O2 sensor. Again, thanks for the help.
May 9, 2006 at 6:20 PM
Suggested Repair
Replace the primary oxygen sensor. Also rule out water in the fuel, incorrect timing, and low compression, and confirm the coil packs are good.
Conversation Summary
A 2002 Honda Civic Si sputtered, stuttered, and backfired while cruising and accelerating, with no trouble codes. Plugs, valve cover gaskets, coil packs, MAP sensor, fuel pump and filter, injectors, fuel rail, throttle body, main relays, ECM, and a cleaned intake manifold did not fix it. Compression, leak-down, timing, connections, and vacuum leaks checked out. After further parts swapping, the owner traced the problem to a bad primary O2 sensor.
