1995 Honda Passport Transmission Leak
BAGMAN1
1995 Honda passport, 125,000 I have a small amount of transmission fluid under the motor in the morning when I leave for work. It seems to shift fine.
Mar 6, 2006 at 9:00 AM
FISHERMAN
  • 937 POSTS
check the oil level often until you fix the leak...
put a piece of cardboard under your car and find out where the leak came from..
could be just a loose screw on the cover or bad gasket.
Mar 6, 2006 at 1:12 PM
Suggested Repair
Check the fluid level often until the leak is fixed. Place cardboard under the vehicle to locate the source. A loose transmission cover screw or a bad gasket may be the cause.
Conversation Summary
The owner of a 1995 Honda Passport with 125,000 miles reports a small amount of transmission fluid under the engine in the morning. The transmission still shifts fine. The expert advises checking the fluid level often, using cardboard to pinpoint the leak, and inspecting for a loose cover screw or bad gasket.
