Honda Distributor Rotor Not Spinning
HONDA
NATTYB4KSU
  • 5 POSTS
Do i need to replace my timing belt, if the rotor underneath the distributor cap is not spinning
May 26, 2006 at 6:56 AM
LOSONE
  • 1,616 POSTS
If the distributer gear is good you will have to replace a lot of things including the cyl head because the engine is an interference engine and a broken timimg belt wipes out the valves. Good luck
May 26, 2006 at 11:16 AM
NATTYB4KSU
  • 5 POSTS
Is there a way to check if the distributor gear is good? If i have to replace all those parts, considering how old my car is, should I just look to get a new one? Thanks for all your help.
May 26, 2006 at 3:36 PM
LOSONE
  • 1,616 POSTS
You didn't provide me the make, model, year and mileage of your car so I can't make an accurate judgement.
If the engine spins over like you have no spark pulgs in the holes then it is a broken timimg belt You can remove the valve cover and see if the valves move when you turn over the engine.
As a reminder, the timing belt replacement on most Hondas is 60K on earlier models and 90K on newer models.
Good Luck
May 27, 2006 at 6:18 AM
Suggested Repair
If the engine turns over freely as if the spark plugs were removed, suspect a broken timing belt. Remove the valve cover and check whether the valves move while cranking. If the distributor gear is good and the belt is broken on this interference Honda, the valves and possibly the cylinder head may need replacement along with the belt. Honda timing-belt intervals are typically 60,000 miles on earlier models and 90,000 on newer ones; year, model, and mileage are needed before deciding on a full repair versus replacement.
Conversation Summary
The owner of a Honda asked whether a timing belt must be replaced because the rotor under the distributor cap is not spinning, and whether the car is worth repairing. The expert said a good distributor gear plus a broken belt on an interference engine can damage the valves and require extensive parts, including the cylinder head. Without year, model, and mileage, a firm judgment was not possible. Suggested checks were free engine rotation and watching valve movement with the valve cover removed.
