94 Accord: Engine Stalls when brakeing fast.
DAKU
I have a 94 Accord 2.2 EX Automatic. Just recently when I break fast ONLY(step on the brake paddle hard) as the car comes to stop near the end it will shut off (at lower speeds, as its downshifting). I have no troubbles starting the car right after (in nutral/park).
Car starts fine everyday and every time. I'ev had the Transmission fluid changed about 10k KM ago. Checked the Transmission Fluid level and its fine. I have noticed because the summer is here and I just replaced my thermostat in winter the car Idls lower then it used to before (400-500rpm)..almost feels like it will shut off.
Can someone please help me diagnose what may be causing this?.
Thanks!!
May 15, 2007 at 3:00 AM
  • 75,988 POSTS
[quote:e6dfdd9e6b="daku"]I have a 94 Accord 2.2 EX Automatic. Just recently when I break fast ONLY(step on the brake paddle hard) as the car comes to stop near the end it will shut off (at lower speeds, as its downshifting). I have no troubbles starting the car right after (in nutral/park).
Thanks!![/quote:e6dfdd9e6b]
Have the EGR,TPS,and Idle air control valve check
May 15, 2007 at 11:22 AM
