1985 Honda Civic Stalls When Braking
JMARTY
I have an 85 Honda Civic 4wd wagon with 170,000 miles. When you press the brake it feels spongy, you hear a hissing sound, then the idle drops. If you hold the brake, the car stalls, only to start right back up again. I'm thinking vaccuum leak, but don't know where to begin. If you help me solve this problem, I will make a donation!
Dec 29, 2006 at 3:08 AM
BRUCE HUNT
  • 3,754 POSTS
Is there a booster on that car to assist with the brakes? They are generally vacuum operated.
Dec 29, 2006 at 7:45 AM
JMARTY
Yes, there is a booster. Would the vacuum in the brake booster be tied in to the vacuum for the whole engine?
Dec 29, 2006 at 11:23 AM
BRUCE HUNT
  • 3,754 POSTS
Generally, yes. The car has to try and regulate the engine speed to overcome the leak.
Dec 30, 2006 at 1:31 AM
JMARTY
Thanks, I tested the brake booster and it appears to be malfunctioning. I am going to replace it in the next couple of days, we'll see if that fixes it. Thanks again, I'll keep you posted.
Dec 31, 2006 at 5:58 PM
Suggested Repair
Test and replace the vacuum brake booster. A leaking booster can pull engine vacuum when the pedal is pressed, causing a hiss, a spongy pedal, a drop in idle, and stalling while the brake is held.
Conversation Summary
The owner of a 1985 Honda Civic 4WD wagon reported a spongy brake pedal, a hissing sound, a drop in idle, and stalling when the brake was held. The expert noted that the vacuum brake booster is tied into engine vacuum and that the engine may stall trying to compensate for a leak. The owner tested the booster, found it malfunctioning, and planned to replace it.
