1992 honda civic dies
HDJ272
I have a 1992 honda civic 16 valve engine which was running well untill yesterday. The car cuts itself down after about 3-5 miles, when you try to restart it will turn over but not start.Then you have to wait about 3-4 hours before it crank up again. Replaced spark plus and wires and distributor but an still having same problem.
Jun 24, 2007 at 8:50 AM
BRUCE HUNT
  • 3,754 POSTS
During the down time when it fails to start you need to determine if there is spark and fuel.
Jun 25, 2007 at 1:18 AM
HDJ272
the vehicle has fuel going to it but i couldn't get a spark out of it.
Jun 25, 2007 at 6:59 AM
BRUCE HUNT
  • 3,754 POSTS
Now, generally the ignitor and coil will flat not give a spark, but this could be one of those situations where one of them is failing slowly and it could be a sensor like the cam or crank sensor. I can't tell you which one it is. There are some tests that you can do. For instance, when it is not starting and no spark exists, see if there is 12 volts of power to the coil. If it has power but nothing coming out of it, replace it.
Jun 25, 2007 at 9:14 AM
HDJ272
Replaced coil. Ran well for about 40 min, Then died again.
Jun 26, 2007 at 2:26 PM
JAY1112G
try changing the ignition control module that shoukd fix the problem.
Jun 26, 2007 at 3:56 PM
HDJ272
Replaced ICM, Works okay for now. Will keep you informed. Thanks for the help, Will recommend you guys to all my friends.
Jun 29, 2007 at 2:13 AM
