Also, my exhaust manifold is cracked. Would this cause lower gas mileage and where can I get the part for a reasonable price? Thanks.
1995 Honda Civic Distributor Order
#1 cylinder on the engine is at the front, next is #2 and so on.
#1 on the distributor cap should be at the nine o'clock position, when looking down at the top of the cap. The direction of rotation is clockwise
You don't want to know how much a dealer price is. Go to a salvage yard and get a $50.00 one. Get Honda factory gaskets--you'll save yur self a lot of time.
A few ways to do this. With both ways, make a point to watch which direction the bottom "crankshaft pulley" is rotating when the starter in engaged.
1) Install compression tester in Cyl #1 (usually the one closest the pulley on 4cyl engines) and have someone tap the key until you see the pressure starting to come up. This will put you on the compression stroke of #1 cyl. Put a socket on the crankshaft bolt and continue rotating the engine (in the same rotation you witnessed earlier) until the TDC mark "0" lines up with the timing pointer on the block.
Then pop open the distributor cap. You should be pointing toward plug wire #1. If not, pull all the plug wires out of the cap and install plug wire #1 right where the distributor is pointing to. Then follow losone’s information on the rest of the firing order based upon the rotation of the rotor inside the dist. cap.
2nd way to do it (if you don't have a compression tester)
Pop off the valve cover and put a socket on the crankshaft bolt and continue rotating the engine (in the normal rotation) until you see the intake valve(s) open and close (easy way to tell the difference between intake and exhaust valves is to see which side is connected to the muffler and which side is connected to the intake, wahh laa exhaust side=exhaust valve / intake side = intake valve - it's really easy to tell)
Now once you see the intake valve open and close keep turning the crank pulley until the TDC mark "0" lines up with the timing pointer on the block. You should now be on "top dead Center" on the compression stroke.
Hope this helps
Suggested Repair
Set the firing order to 1-3-4-2, with cylinder 1 at the front of the engine and distributor terminal 1 at the nine o'clock position when viewed from above; rotor rotation is clockwise. Confirm cylinder 1 is at TDC on the compression stroke before installing the plug wires. For the cracked exhaust manifold, use a salvage-yard manifold with Honda factory gaskets; replacement takes about two hours if the bolts are not seized or broken.
Conversation Summary
The owner of a 1995 Honda Civic EX 1.6 had mixed up the distributor plug-wire order after a tune-up and also reported a cracked exhaust manifold. An expert stated the firing order is 1-3-4-2, with cylinder 1 at the front and terminal 1 at nine o'clock, rotating clockwise. Another reply explained how to find TDC on the compression stroke and place wire 1 where the rotor points. For the manifold, the expert recommended a roughly $50 salvage part with Honda gaskets and estimated about two hours if bolts are not frozen or broken. Lower fuel mileage from the crack was not directly confirmed.
