Honda Speedometer Odometer Not Working Fix
HONDA
CIVICUSER
  • 13 POSTS
is it possible just to replace the gears on the speedometer and odometer, instead of change the whole cluster when your speedometer and odometer are not working?
Nov 7, 2006 at 6:50 PM
BRUCE HUNT
  • 3,754 POSTS
Of course you can buy the speedometer and take it appart and see what you can do to tinker with the insides. I buy a used cluster, pull out the speedometer and install that one.
Nov 8, 2006 at 2:18 AM
Suggested Repair
Buy a used instrument cluster, remove its speedometer, and install that unit. The speedometer can also be taken apart so the internal gears can be inspected and repaired if possible.
Conversation Summary
The owner of a Honda asked whether the speedometer and odometer gears can be replaced instead of the entire instrument cluster when both gauges are not working. The expert said the speedometer can be disassembled and repaired, and recommended installing a speedometer taken from a used cluster.
