1996 Honda Accord Odometer Stopped
WILGILB
My daughter's 1996 Accord 4 cyl, auto, 107,000 miles, just had an oil change with a questianable mechanic. 37 miles after leaving the shop, the odometer stopped, then started, then stopped. The speedo is fine.
My Haynes manual doesn't mention the speedo or odometer.
My Honda CD is just as helpful.
Do you have suggestions?
Where would I find complete schematics for this car?
Tip follows.
Thanks,
Bill
Jan 27, 2007 at 7:17 AM
BRUCE HUNT
  • 3,754 POSTS
Being intermittent will be fun, but since the mechanic was under the car and could have accidently disconnected a connector, I suggest looking at the transmission for a broken wire or loose connection of the vehicle speed sensor. (VSS)
Jan 28, 2007 at 1:17 AM
Suggested Repair
Inspect the transmission for a broken wire or loose connector at the vehicle speed sensor (VSS), which may have been disturbed during the oil change.
Conversation Summary
The owner of a 1996 Honda Accord reports that the odometer stopped, restarted, then stopped again about 37 miles after an oil change, while the speedometer continued working. The expert suggests checking the transmission for a broken wire or loose vehicle speed sensor connector that may have been disturbed under the car.
