1995 Honda Civic Squeaky Steering
DONLIVE1
I own a 1995 Honda Civic Coupe DX 1.5 litre engine automatic transmission, it has 182,000 kilometers and is running excellent. I just recently I noticed that everytime I either steer slightly to the right or left I'm hearing squeeky sounds from the front of the engine. It sounds as if its rubber rubbing against itself. I would appreciate any suggestions from anyone who has experienced this kind of problem and a rough estimate in price.
thanks.
Don
Jul 3, 2007 at 2:39 AM
BRUCE HUNT
  • 3,754 POSTS
Generally the first place I would look when the sound is related to turning is to examine the steering pump belt. That can get old and glazed and then slip. Have someone assist and see if it is coming from there. Replace the belt.
Jul 3, 2007 at 3:25 AM
Suggested Repair
Have an assistant help locate the squeak while the steering is turned. Inspect the power steering pump belt for glazing or slipping, and replace the belt if it is the source.
Conversation Summary
The owner of a 1995 Honda Civic reports a rubber-like squeak from the front of the engine when steering slightly left or right. The expert recommends checking the steering pump belt, which can become glazed and slip, and replacing it if confirmed.
