2004 Honda Civic Speedometer Drops to Zero
ANDYKOEBERL
I have a 04 Civic with 69000 miles on it and I am having a problem with the speedometer. All of the other guages and odometer work fine. When I am driving the speedometer will sometimes work fine for a while and then it will either stick at a certain speed or will gradually go to zero from my current speed and it wont do anything for a while. Then later on it will work again.
The delaership said I need a new instrunment cluster but I am skeptical. Can someone please help?
Thanks
Sep 12, 2007 at 8:22 AM
BRUCE HUNT
  • 3,754 POSTS
I believe in this case they are correct. Your decision to be made is whether to spend the $ on a new guage or a used one. I am sure that a used one can be found.
Sep 12, 2007 at 8:58 AM
Suggested Repair
Replace the instrument cluster. A used cluster is a reasonable lower-cost option if a new one is too expensive.
Conversation Summary
The owner of a 2004 Honda Civic with 69,000 miles reports that the speedometer intermittently sticks or gradually drops to zero, then later works again, while the other gauges and odometer work normally. The dealer recommended a new instrument cluster. The expert agrees and says the owner can choose a new cluster or a used one, which should be available.
