1993 Honda Civic Speedometer Drops
1993 ALL OTHER MAKES ALL OTHER MODELS
TCENTER
93 Civic DX Electrical Issues
I have a 1993 Civic DX. 1.5L 5 Speed. 162,000 Miles. I have an electrical problem. My speedo intermittently dies, but I am not loosing DC power. I had the battery and alternator checked, no problem. The other day, this happened and the engine actually shut off. I was accelerating so it was very noticable that the engine quit. Without stopping I was able to shut off the ignition, and restart. (I'm a Windows Administrator, so that was the first thing that came to mind, quickly reboot.) Since then, about 4 or 5 more times my speedo drops to 0, then 1 or 2 seconds later comes back on. Any ideas? I'm worried the problem is going to escalate. My mechanic has no idea what that could be and I'm not paying him to trouble shoot. Maybe you can help... Thank you... I'll donate if you answer my question, I'm just new here so I'm not sure about your forum.
Jan 21, 2007 at 5:59 AM
BRUCE HUNT
  • 3,754 POSTS
I would look to the Vehicle Speed Sensor.
Jan 22, 2007 at 5:33 AM
TCENTER
UPDATE - Well since my last post, my car has not died again, which is a good thing. But, the speedo routinely drops to 0 and stays there for sometimes up to 5 mintues. I checked Honda e-store, $120 for the sensor. I removed and blew out the connection to make sure it wasn't wet or anything.. Thank you.
Jan 23, 2007 at 1:58 AM
Suggested Repair
Inspect and test the vehicle speed sensor and its electrical connector. Clean the connector if needed and replace the sensor if the speed signal remains intermittent.
Conversation Summary
The owner of a 1993 Honda Civic DX reported the speedometer intermittently dropping to zero without a loss of battery power. The engine shut off once while accelerating and restarted after the ignition was cycled. The battery and alternator tested fine. An expert recommended checking the vehicle speed sensor. The owner later said the stall had not recurred, but the speedometer still dropped to zero for up to several minutes after the sensor connector was cleaned.
