1999 disco 2 engine shuts off
1999 ALL OTHER MAKES ALL OTHER MODELS
PLANET10
I have a 1999 Discovery 2 with 116,000 miles. It had overheated one day in November 06 and blew a hose. I had it repaired and then it all went to hell. The mechanic stated that the car was in need of a head gasket due to the missfire and the coolant system pressurizing too much. They fixed that and now i have a car that will not stay idle. while in the hands of the repair shop, the car was at idle then it just stopped. the check engine light was on and the car would not restart, it would sound like it fired but would shut down right away. after letting it sit for 10 minutes it would start again and remain on for 5 - 10 minutes and shut down. Mechanic stated i needed a new battery as a code shown "improper voltage to operate" put in a new battery now the alarm is acting funny, no lights just a beep of the horn without locking and still will only idle for about 5-10 min. so today we looked at it and the new battery was drained, jumped it and it started.
we pulled the engine and aux relays from the fuse panel and cleaned them and the car idled for about 1 hour and shut down and goes back to 5-10 min of idle.
so are the relays bad, is the computer shorted, is the alarm causing this, or what???????? the mechanic that did the heads is of no use at all.we are at our wits end since the car idles great, starts right up then it just shuts off.
PLEASE HELP, I SPENT 1500.00 FOR THE HEADS TO BE DONE AND IT WONT RUN!!!!
Jan 5, 2007 at 7:38 AM
SERVICE WRITER
  • 9,123 POSTS
Is the alarm aftermarket or OEM?
Jan 5, 2007 at 1:23 PM
PLANET10
it is the standard unit. as i said before, the unit wil not arm it only beeps the horn once without the lights flasshing and locks engaging. they will only lock if i hit the button by the clock and then use the key on the door lock to lock the driver door.
i did receive a call from the mechanic after he put it all back together if i knew how to fix the alarm so the car can start. i did not know, he called the dealer and he said he input some codes in and was able to start the car. it ran fine for 4 days and then as i was to take possesion of the vehicle, it was running and then stopped and hence my dilema has been such for the last week.
please contact me directly at
planet10studios@comcast.net
thanks fo rthe response
Jan 5, 2007 at 3:15 PM
SERVICE WRITER
  • 9,123 POSTS
We have some pretty darn good guys on this site, and maybe one of the others can chime in.
You need to go back to basics, it may not be related to anything previous...or it may.
If no one responds here, my suggestion is to check with the local snap on tool dealer and have them refer you to a shop. They deal with the good, bad and the ugly and can point you in the right dirction for hands on help
www.snapon.com
Jan 5, 2007 at 3:21 PM
