1998 Honda Accord Rough Idle
GARY COOK
My 1998 Honda Accord 4 cylinder idles very rough but smooths out with just a 100 to 200 rpm increase. How do you adjust the idle? And what rpm's should it be with and without the a/c on
Sep 27, 2007 at 2:56 PM
  • 75,988 POSTS
When was it last major tuned-up? could be also the idel air control valve/speed controller-open it up and clean it.
Sep 27, 2007 at 7:54 PM
BRUCE HUNT
  • 3,754 POSTS
It should idle at around 750 rpm + or - 50 rpm. This should remain pretty consistent even when the A/C kicks in.
What i think Raz was pointing to for you was to look at the engine as a whole to find of out if there is a cause for a low idle. However, there is a idle set screw on the the throttle body.
Sep 28, 2007 at 1:54 AM
Suggested Repair
Check when the engine was last tuned up and inspect the engine as a whole for a low-idle cause. Clean the idle air control valve. Target idle is about 750 rpm, plus or minus 50 rpm, and it should stay fairly consistent with the A/C on. An idle set screw is also located on the throttle body.
Conversation Summary
The owner of a 1998 Honda Accord 4-cylinder reports a very rough idle that smooths out with only a 100 to 200 rpm increase, and asks how to adjust idle and what rpm is correct with and without A/C. Experts recommend checking the last major tune-up, cleaning the idle air control valve, and looking for an underlying cause of low idle. They state idle should be about 750 rpm plus or minus 50 rpm and remain fairly consistent when the A/C is on, and note an idle set screw on the throttle body.
