1992 Honda Accord Rough Idle at Start
JOEAR
Very rough idle when I start my 92 accord 5sp with 226K. Last 5 to 20 seconds then runs perfect. At times it starts and idels perfect other times a rough idle from mild to very rough occurs. I changed the cap, roter, and plugs. I even tried fuel injector cleaner thinking it might help. This only occurs when I start the car no matter how long it has sat 5 min or 24 hrs., hot or cold.
Sep 8, 2007 at 1:10 PM
BRUCE HUNT
  • 3,754 POSTS
You might check these three things to start with:
1. Idle Air Control - take it off and clean it. There are screensin it and it has coolant flowing through it as well as air.
2. PCV valve - should only let air flow one direction
3. EGR valve - take it off and clean. Check it for easy operation.
Let us know how you are doing.
Sep 10, 2007 at 2:01 AM
Suggested Repair
Clean the idle air control valve, verify the PCV valve flows only one way, and remove and clean the EGR valve while checking that it moves freely.
Conversation Summary
The owner of a 1992 Honda Accord manual reports a rough idle for about 5 to 20 seconds after starting, then normal running. It happens intermittently whether the engine is hot or cold and after short or long sits. Replacing the cap, rotor, and plugs and using injector cleaner did not help. The expert recommends cleaning the idle air control valve, checking the PCV valve for one-way flow, and cleaning and checking the EGR valve.
