I drive a '97 Accord, 2.2, with 115,000 miles on it. Recently it has been idleing rough on start up, subsiding in 10-20 seconds or when I give it some gas repeatedly. In addition to this, the sensor indicated overheating once while it was idleing for a few minutes. I had my repair guy run some tests after the engine light came on. He said it was a valve misfire, and came to the conclusion that the head gasket needed replacing, taking into consideration that my radiator blew a couple months back and the car overheated. However, there is no noticeable leakage from the head, and a bad head sounds unlikely. Furthermore, today the car started to 'overheat' while I was idleing for only a couple of minutes, yet the fluid resovoir was full. Could the two issues be unrelated? - Could the idleing be caused by something like an air filter or fuel injector problem? And why the overheating?
I appreciate any advice you can offer. Thanks.
Jul 12, 2007 at 7:49 AM
