1986 Honda Accord Engine Overheating
EMARIEWILLING
I drive an 86 Accord with over 100,000 miles on it...
Yesterday I was driving on the highway and noticed that my car was getting extremely hot. It had problems overheating before, but usually only when idling, so this was really unusual.
I pulled over, and when I slowed down the car just absolutely died. It wouldn't start again at all, and white smoke was coming out of the engine area. I checked the oil and it seemed to be fine, but all of my water was gone.
I'm a young girl -- I know [i:3f11d68058]nothing[/i:3f11d68058] about cars. I'm really afraid of being swindled by mechanics, so I was hoping to get a good idea of what might be wrong before I took it in. Does anyone have any ideas?
:cry:
Mar 7, 2006 at 3:42 AM
FISHERMAN
  • 937 POSTS
your head gasket its gone..
you will need a head gasket, resurface and valves job.
with no water the aluminum head expands and sometimes twist, burning the gasket.
Mar 7, 2006 at 9:14 AM
JTCHURCH
You're sure huh?
An empty coolant resevoir must mean blown head gaskets, twisted aluminum and a valve job?
Or was it the white smoke and trouble starting it again right away? -two things that will happen with any severely overheating engine regardless of the cause.
Just curious. :roll:
Mar 7, 2006 at 10:50 PM
FISHERMAN
  • 937 POSTS
not at 100% but have it check... probably its something minor.... (i hope)
good luck!
Mar 8, 2006 at 12:51 AM
BRUCE HUNT
  • 3,754 POSTS
This is probably the head gasket and depending on the circumstances you could have additional problems.
Another possibility as well is the intake gasket if the coolant flows through it. 96 accords have coolant coming in to the intake manifold.
I ask if this is a fuel injected vehicle and it might be worth considering that if the head is bad, etc. I would consider getting a newer honda.
Mar 9, 2006 at 5:20 AM
HEATHER ROLLINS
definately the head gasket same thing happened to my car
Apr 27, 2011 at 2:42 PM
PRAKASHKING
just pour full water then check is there any leakage if no open the radiator cap and notice any bubble are coming out if yes change head gasket.
Apr 21, 2012 at 1:56 AM
  • 110,248 POSTS
Never open the rad cap with the engine hot. Refer to our home page under the diy section. Check for engine compression.
Jun 25, 2012 at 7:10 PM
Suggested Repair
Do not open the radiator cap while the engine is hot. Have coolant leaks and engine compression checked before authorizing major work. Lost coolant, highway overheating, white smoke, and a no-start suggest a possible head gasket failure; if confirmed, the aluminum head may need inspection or resurfacing, and a valve job was mentioned as a possible related repair.
Conversation Summary
The owner of a 1986 Honda Accord with over 100,000 miles reported highway overheating, a stall and no-start, white smoke from the engine area, normal-looking oil, and an empty cooling system. One expert initially said the head gasket was gone and that the head might need resurfacing and a valve job, then said it was not certain and should be checked. Another expert also suspected the head gasket, mentioned a possible intake-gasket issue on some Hondas, and suggested considering a newer vehicle if the head was damaged. A later expert warned never to open a hot radiator cap and recommended an engine compression test.
