1992 Honda Accord Overheating at Idle
After it warms up do you see water dripping out of the tail pipe or white smoke.
Could be the pump: check and see while engine is hot and idling squeeze the upper hose while you rev the engine do you feel a strong flow going thru. i f not the impeller might be gone.
Doing a block check-will tell if the headgasket is leaking by the present of hydrocarbons. Fluid will turn yellowish .
Pressure test the radiator cap.
Suggested Repair
After warmup, check for coolant dripping from the tailpipe or white smoke. With the engine hot and idling, squeeze the upper radiator hose while revving and confirm strong coolant flow; weak flow points to a failed water pump impeller. Also perform a block test for hydrocarbons and pressure-test the radiator cap.
Conversation Summary
The owner of a 1992 Honda Accord reports overheating at low RPM that improves on the highway and when the engine is revved to about 2000 RPM. The fans work, the thermostat was removed, the water pump is recent, the oil looks normal, and the coolant is low after cooldown. The expert suggests checking for exhaust steam or dripping, verifying hose flow for a failed impeller, doing a block test for a leaking head gasket, and pressure-testing the radiator cap.
