2002 Honda Accord Rough Idle
BADAIM
2002 Honda Accord V6 EX - just started idling roughly yesterday. Idle runs from about 900 to 1900 and bounces back and forth rythmically over a period of about a second. It occurs soon after starting and continues. At first there was no "Check engine" light but after taking it for a test drive (WIfes car) and turning on the A/C, the "Chech engine" light is on and the 'TCS' light stays lit. Also the rythmic bouncing of idle is 3 times as fast, fluctuating from about 1200-1500. I think it might be the Idle Air Control Valve, but the local shop wants almost $100 just to check it out. After that is all the parts and labor. The car has 110,000 miles and has always been dealer maintained. The last trip the mechanic said "boy you really keep this car in great shape!". Any pics of the Honda V6 accord motor showing the IACV location? It was easy to find the MAP sensor. There are so many sensors on the Honda, I don't want to just replace them all! There is a sensor on the top (Clearly marked 'MAP sensor') one on the front side towards grill, and one on the bottom of intake. There are also several others. The one on the bottom has a couple of 5 star Torx looking screws. Are they trying to really prevent us from changing that one? Any help in figuring out which one is the IACV if that is the culprit? I sent a couple pics. Thank for any help.[img:be26209fc1]http://www.2carpros.com/forum/automotive_pictures/72442_Multiple_sensors_2.jpg[/img:be26209fc1][img:be26209fc1]http://www.2carpros.com/forum/automotive_pictures/72442_5_star_torx_2.jpg[/img:be26209fc1]
May 4, 2007 at 6:47 AM
2CARPRO JACK
  • 11,533 POSTS
I have replaced a few of them for that exact problem. They use a rotating valve assembly instead of a needle-and-seat style and they tend to gum up and not want to work properly. I believe your is on the bottom rear of the throttle body
May 4, 2007 at 10:32 AM
BRUCE HUNT
  • 3,754 POSTS
They have two hoses hooked to them for a coolant to flow through them. The valve senses the temp of the system. That might help you ID the part.
May 7, 2007 at 5:46 AM
BADAIM
I replaced it successfully!
It was the one on the bottom. What a pain to get to without the right equipment. I needed one of those #2 phillips with a ratchet attachment because of theclearance. Made due with what I had. Took 3 times as long, but I saved a bunch of money over taking it in for diagnostics for what I already suspected was the problem. Thanks very much for your help. Valuable service. I'll use it again.
Thanks again,
Bob
May 11, 2007 at 11:25 AM
Suggested Repair
Replace the idle air control valve on the bottom rear of the throttle body. Identify it by the two coolant hoses; the rotating valve assembly commonly gums up and causes this surging idle.
Conversation Summary
A 2002 Honda Accord V6 developed a rhythmic idle surge, then the check engine and TCS lights came on after a drive with the A/C on. Experts said the IAC valve uses a rotating assembly that gums up, sits at the bottom rear of the throttle body, and can be identified by two coolant hoses. The owner replaced that bottom valve and confirmed the idle problem was fixed.
