1998 Honda Accord Rough Idle
What i think Raz was pointing to for you was to look at the engine as a whole to find of out if there is a cause for a low idle. However, there is a idle set screw on the the throttle body.
Suggested Repair
Check when the engine was last tuned up and inspect the engine as a whole for a low-idle cause. Clean the idle air control valve. Target idle is about 750 rpm, plus or minus 50 rpm, and it should stay fairly consistent with the A/C on. An idle set screw is also located on the throttle body.
Conversation Summary
The owner of a 1998 Honda Accord 4-cylinder reports a very rough idle that smooths out with only a 100 to 200 rpm increase, and asks how to adjust idle and what rpm is correct with and without A/C. Experts recommend checking the last major tune-up, cleaning the idle air control valve, and looking for an underlying cause of low idle. They state idle should be about 750 rpm plus or minus 50 rpm and remain fairly consistent when the A/C is on, and note an idle set screw on the throttle body.
