1999 Honda Accord P0401 EGR Flow
BILLNJ
  • 7 POSTS
1999 Honda Accord EX, 131,000 miles, 4 cyl, Manual Trans. Check engine light came on and I retrieved the above OBD II code indicating the following as possible causes:
-The DPF (differential pressure) sensor is faulty and needs to be replaced
-There is a blockage in the EGR (most likely carbon buildup)
-The EGR valve is faulty
-The EGR valve may not be opening due to a lack of vaccuum
There has been no noticable change in engine performance. Is there a way to determine which of the above problems is the culprit? I would assume the last one (lack of vaccuum) is not the problem since this EGR valve appears to be operated electrically.
Jul 10, 2007 at 6:41 AM
BRUCE HUNT
  • 3,754 POSTS
Take the EGR off and clean it. It is likely that it doesn't close all the way due to carbon build up. If that satisfies the computer or the CEL, then I would next proceed to find out why the carbon buildup which generally to rich a mixture. Could be timing, o2, etc.
Jul 11, 2007 at 3:15 AM
Suggested Repair
Remove and clean the EGR valve, which may not close fully because of carbon buildup. If the check engine light clears, investigate why carbon formed, commonly a rich mixture related to timing or oxygen sensors.
Conversation Summary
The owner of a 1999 Honda Accord with code P0401 (insufficient EGR flow) and no noticeable performance change asked how to distinguish a faulty differential pressure sensor, EGR blockage, a bad EGR valve, or lack of vacuum, noting the valve appears electrically operated. The expert advised removing and cleaning the EGR valve because carbon can prevent it from closing fully. If that clears the light, the next step is to find the cause of the carbon buildup, often a rich mixture from timing or oxygen-sensor issues.
