2005 Honda Accord Rough Run Then No Start Fix
FLOYDB
I have a 2005 Honda Accord: 15,300 miles. I stopped and filled up the gas then drove approx. 30 miles. When I stopped at the mail box the car ran really rough and the engine (emissions) light came on. I pulled into the carport, still running really bad, and turned the car off. Checked the gas cap, the oil is ok (just changed) and everythig else looks to be ok. Now the car won't turn over, just one click and nothing. The exaust smelled bad when I parked it. Not running hot. Could it be bad gas, O2 sencer, or cat. converter? Should I have it brought to the dealer since it is still under warranty or is there a simple fix? What to do?
Dec 25, 2006 at 1:15 PM
BRUCE HUNT
  • 3,754 POSTS
Off to the shop it should go.
Dec 28, 2006 at 6:37 AM
FLOYDB
Has been picked up and brought to the shop. The starter went out and the mech. had to order a new one. Then he will be able to check the rest of the car.
Dec 29, 2006 at 3:43 AM
BRUCE HUNT
  • 3,754 POSTS
That should be a warranty replacement. Good job!
Dec 29, 2006 at 7:46 AM
Suggested Repair
Have the failed starter replaced under warranty, then let the shop diagnose the rough running and emissions light.
Conversation Summary
A 2005 Honda Accord ran roughly with the emissions light on after a fuel stop, then would not crank and only clicked. The owner was advised to take it to a shop. The shop found the starter had failed and ordered a replacement, which the expert said should be covered under warranty.
