How do you change the EGR valve on my accord and how do you turn off the maintenance light?
May 12, 2006 at 10:16 AM
LOSONE
✓Experienced Mechanic
Hold in the trip switch on the instrument cluster. Turn the key on. Wait for the maint light to stop flashing and it is reset.
The EGR valve is a bear to change and should go to a dealer. Whay do you want to change it? Let me know.
May 13, 2006 at 7:29 AM
TURBOPARK
MEMBER
Because the check engine light came on and I took it to autozone and the computer said it was the EGR valve. My friend is pretty good with his hands and he said he'd probably be able to replace it though he's never done it before. How much do they charge at a mechanic? I know dealership will probably be more expensive.
May 13, 2006 at 7:46 AM
LOSONE
The Zone scanners don't tell the whole story. There are several sensors that can set an EGR valve code. Take it to a mechanic with a scanner that can read the data stream. I would hate to see you go through all the labor and the light would still be on.
What ever you do do not buy an EGR valve from the Zone. They are made in China and not very good.
May 13, 2006 at 7:55 AM
TURBOPARK
MEMBER
Thanks I'm going to check on it. You've been great help.
