1990 Honda Accord Speedometer and CEL
DORIO
90 Honda Accord/Manual Transmission/155000(+-) km -The Check Engine Light came on and at the same time the speedometer failed (and as a result no odometer function). Repair Shop said computer needed rebooting, but that didn't work. Now they say I need a new computer - cost in the $800 range. Does this sound reasonable? Is the computer a salvagable part - available maybe from auto wreckers? Other messages on this website mention a speed sensor problem. Is that a possibility with my car?
Jun 24, 2006 at 3:09 AM
SYNCRAIT
  • 235 POSTS
before you get that indepth run to the auto parts store and ask to use their code scanner once you get the code post it back here and we can help you further and see if there isnt a cheaper fix....good luck :)
Jun 24, 2006 at 3:28 AM
CODY-ODY
  • 57 POSTS
the VSS (vehicle speed sensor) is a very big possibility,its located on the top of the transmission and should have 3 wires to it .
I would unplug this first to see if the terminals aren't corroded or loose. If they look good take it to another garage (your best chance would be a dealership as they have seen all these problems before and would be the quickest diagnosis) and dishout the money (usually about a half hour to one our of labor) to check the problem and give you a run down on whats wrong and what it would cost to repair it.
Jun 26, 2006 at 11:55 AM
Suggested Repair
Scan for trouble codes first. Inspect the vehicle speed sensor on top of the transmission and its three-wire connector for corrosion or loose terminals. Get a second diagnosis from a dealer or another shop before replacing the computer.
Conversation Summary
Owner of a 1990 Honda Accord reports the check engine light came on and the speedometer and odometer stopped working. A shop rebooted the computer without success and quoted about $800 for a new computer. Experts recommend scanning codes, checking the vehicle speed sensor and its connector, and getting a second diagnosis before replacing the computer.
