1990 Honda Accord check engine light
FREEBIRDEMERY
Engine Mechanical problem
1990 Honda Accord 4 cyl Front Wheel Drive Manual
if the check engine light doesnt turn off when you turn key over car will not start
Sep 12, 2008 at 11:12 AM
  • 31,937 POSTS
Hi there,
the ECU has detected a fault in the engine management system, you will have to get a scan to read the set fault code, this code will identify the system or systems that are faulty, start here.
Mark (mhpautos)
Sep 12, 2008 at 11:26 AM
