Are these two related and does the blue smoke mean i need new stem valve seals or have to replace the ecu or what. its been happening for a while and i have absolutely no idea what it could be... cheers
1989 Honda Accord Blue Smoke and CEL
Suggested Repair
Blue smoke means the engine is burning oil. Check whether the oil level drops and inspect the spark plugs for black, oily deposits. If the engine is using oil, suspect worn valve seals or piston rings. The check-engine code does not prove the ECU itself is bad; wiring shorts or loose connections can set it. Clear the code and see whether it returns.
Conversation Summary
The owner of a 1989 Honda Accord reports that after a few kilometers at highway speed the check-engine light comes on, the car briefly blows blue smoke, and the light stays on. The stored code indicates a faulty ECU, and the owner asks whether that is related to valve stem seals. The expert explains that blue smoke means oil is being burned and recommends checking oil consumption and plug condition. Oily plugs and oil use point to failing valve seals or rings. The expert also notes that a check-engine code only points in a general direction and can be caused by wiring problems, so the code should be cleared and monitored.
