1988 Honda Accord Starts Then Dies
DELSKY06
1988 Honda Accord LXI, 214,000 k Have had car since she was new. (had) Replaced clutch, timing belt, water pump at 205,000k at 210,000k had oxygen sensor replaced. With warm weather I had to open gas cap release pressure wait then she would start. Then when that failed I was instructed to use small amount of starter fluid in the intake. That worked. Check engine light is off and on. Then with cold weather no problem, she started everytime. Now with cold weather both removing gas cap and adding small amount of starter fluid she starts then dies, starts and dies???? What to do now?? Thank you.
Dec 1, 2006 at 4:32 AM
BRUCE HUNT
  • 3,754 POSTS
This is Fuel injected, right? Have you had a pressure test done on the fuel system? Have you replace the fuel filter?
Dec 1, 2006 at 5:59 AM
DELSKY06
Yes, it is fuel injected, and will start with checking fuel system, do you mean check pressure in fuel pump? And will check fuel filter. Thank you again.
Dec 1, 2006 at 6:32 AM
BRUCE HUNT
  • 3,754 POSTS
You should check the fuel pressure at the rail where the injectors are located.
Dec 1, 2006 at 7:24 AM
Suggested Repair
Check fuel pressure at the injector rail and inspect or replace the fuel filter if needed.
Conversation Summary
The owner of a 1988 Honda Accord described intermittent check-engine light and hard starting. In warm weather, releasing fuel-cap pressure and using a small amount of starter fluid helped it start; in cold weather it now starts and then dies. The expert confirmed it is fuel injected and advised testing fuel pressure at the injector rail and checking the fuel filter.
