Tune up was done when I replace the sensor, replace the spark plugs, timing belt and I think they did somethign with the fuel injector...not surre
1999 Honda Accord Lean Idle Stall
Check the spark plugs, fuel injector,vacuum leak and compression.
if so honda has a tsb for this and a repair kit. the fuel pressure regulator is to blame.
for the life of me i can't understand why people are constantly throwing o2 sensors at rich and lean problems.
Suggested Repair
Confirm the lean code (likely P0171) rather than repeatedly replacing the oxygen sensor. Check for vacuum leaks, and have the fuel pressure regulator tested; a Honda TSB and repair kit address this failure. Also verify spark plugs, fuel injectors, and compression if the low-idle stall continues.
Conversation Summary
A 1999 Honda Accord with about 91,000 miles has a recurring check engine light and sometimes stalls in neutral because idle speed drops very low. An oxygen sensor and EGR valve were replaced, and a tune-up including plugs and the timing belt was done, but the light returned. One expert advised checking plugs, injectors, vacuum leaks, and compression. Another said the code was likely a lean condition, not a bad oxygen sensor, and that a Honda TSB and repair kit point to the fuel pressure regulator, which the dealer had also suggested.
