2000 Honda Accord EGR Light
You need to remove the egr valve and clean the egr ports and valve with carb or intake cleaner. If that doesn't solve it, probably need a new valve.
P0401 showing?
Out of warranty.
http://www.carcomplaints.com/Honda/Accord/2000/tsbs.shtml
This is a common problem on v-6 motors in the later models. It is a couple hour job. You must remove the intake plenum to fix this problem. Take off all the plastic covers, then unbolt the throttle body (two nuts, two bolts). Don't take it off though, just
unbolt it. Then unbolt the intake plenum and disconnect all the hoses and electrical connectors at the rear. Tap the throttle body with a mallet where
it connects to the plenum and it will pop loose. Then just lift the plenum and pull it loose from the throttle body. Turn it over on a bench and use a 5/16" bit to drill out the EGR passage near the front of the plenum. Don't use a drill motor , only hand turn. The gaskets are reusable. Reassemble.
Another TSB refers to (99-085) is a product update to re-route the PCV hose to a different place in the intake manifold away from the EGR port.
Suggested Repair
Confirm any EGR warranty extension with the dealer using the VIN. Clean the EGR valve and clogged EGR passages in the intake plenum; valves are rarely the fault. If the code remains, replace the EGR valve. A related update reroutes the PCV hose away from the EGR port.
Conversation Summary
A 2000 Honda Accord EX-V6 with about 81,000 miles has a check engine light the dealer attributes to poor EGR airflow, and the owner asks whether TSB 011001 still covers it. The expert says the vehicle is out of warranty, the number was not found as valid, and the usual fix is cleaning the EGR ports and valve rather than replacing the valve. After the owner cites an EGR clogging warranty extension, the expert advises calling the dealer with the VIN and describes removing the intake plenum to clean the passages, noting a related PCV hose reroute update.
