1989 Honda Accord Low Alternator Output
AHONDANUT
  • 13 POSTS
It's been a while since my last post. I have a 1989 Accord DX 2.0 ltr 4cyl. Autotrans. The alternator is bad. My repair manual says I have to remove the drive axel to remove the bad alt. Is this true??? or are they leading me the long way??? :roll:
Thanks in Advance
:wink:
Aug 27, 2007 at 1:20 PM
  • 75,988 POSTS
[quote:ffddaf1e9e="ahondanut"]Hello,
Thanks in Advance
:wink:[/quote:ffddaf1e9e]
Its gonna take you till X-mas if you follow those YoYo's-Go fine it and use your 6 senses. If you're getting paid working on your own car, you can remove the 1/2 shaft to increase the labor charges-disregard the book's 12 steps-use your imagination.
BTW what's wrong with the Alty-did you confirm all your tests to prove its dead.
Aug 24, 2020 at 7:43 AM
AHONDANUT
  • 13 POSTS
The dummy light (battery) is on, and I checked the voltage output with digital meter while engine running and got low output. It might just be the voltage regulator is bad and I'm assuming it's an internal one. is this correct? :?
  • 75,988 POSTS
[quote:fd3494b99a="ahondanut"]The dummy light (battery) is on, and I checked the voltage output with digital meter while engine running and got low output. It might just be the voltage regulator is bad and I'm assuming it's an internal one. is this correct? :?[/quote:fd3494b99a]
Triple check all the connections at battery and behind the Alty-I don't think it has an external IVR-if you wish you can go inside and pull a CSI on it-could be a solder problem or whatever.
Suggested Repair
Recheck the battery and alternator connections and confirm the low charging voltage before replacing parts. The Accord is believed to use an internal regulator, so an internal inspection for a regulator or solder fault may be warranted; axle removal was not confirmed as necessary.
Conversation Summary
The owner of a 1989 Honda Accord DX says the alternator is bad and asks whether the drive axle must be removed. The expert discourages following an unnecessarily long procedure and asks whether the failure was confirmed. The owner reports a battery warning light and low voltage with the engine running, and asks if the regulator is internal. The expert advises rechecking the battery and alternator connections, says an external regulator is unlikely, and notes that an internal inspection might reveal a solder or regulator problem.
