1997 Honda Accord Battery Goes Dead
Suggested Repair
Check the battery and starter cables and connections. With the engine running, charging voltage at the battery should be about 14 volts; about 12 volts indicates the alternator is not charging, even if bench tests passed, and the fault may be intermittent. Also consider a starter that continues to draw current while the vehicle is running.
Conversation Summary
The owner of a 1997 Honda Accord with about 190,000 miles reports a two-week-old battery going dead after roughly three hours of driving, even with accessories off. The alternator and battery tested good, but the engine dies if the battery is disconnected while running, and the owner measured about 12 volts at the battery. The expert advised checking battery and starter cabling and connections, noting a possible continuous starter draw, and said about 12 volts while running points to an alternator charging problem that may be intermittent.
