2003 Honda Accord Radio Locked After Battery
SPLUNGE
I had to remove the battery to replace the driver side low beam bulb. When I tried to reset the clock or use the radio I could not. Help
2003 honda accord vtec 6 cyl. 35K miles
May 19, 2006 at 1:16 PM
BRUCE HUNT
  • 3,754 POSTS
Check your owners manual or the documents that came with the car. There should be a 5 digit code that came with it. If not, then you will need to find the serial number of the radio and take that and the proof of ownership to the dealer and have them look up the code on their website. They will usually do this for free. Get the number and store it safetly for future use.
May 23, 2006 at 5:46 AM
SPLUNGE
The code is on a sticker on the inside of the glove box door. I called the dealer and got the code and later noticed that the number they gave matched the sticker.
May 23, 2006 at 4:37 PM
Suggested Repair
Enter the radio anti-theft code to restore the radio and clock. Find the 5-digit code in the owner's documents or on the sticker inside the glove box door. If it is missing, take the radio serial number and proof of ownership to the dealer so they can look up the code, then store it safely.
Conversation Summary
After the battery was removed to replace a low-beam bulb, the 2003 Honda Accord radio and clock would not work. The expert explained that the radio anti-theft system needs its 5-digit code, available in the owner's documents or from the dealer with the radio serial number and proof of ownership. The owner later confirmed the code was on a sticker inside the glove box door and matched the code given by the dealer.
