So im driving n all of the sudden the car just dies on me. I tried starting it again but no luck. You can here it crank but will not start. I check the spark plugs, the engines compression, the muffler to see if it was clocked up, the starter relay, I also put some gas directly to engine to see if it was the gas pump but no luck. So I took a risk n changed the distriburator and turn on like a charm. It worked for about a week and then I just got the same problem so I thought the distriburator was bad since it was reconstructed, I changed again but this time no luck. Any one has any suggestions.
SPONSORED LINKS
Sunday, August 24th, 2008 AT 6:01 PM
