1993 Honda Accord car won't start periodically unless until
PAULIE3
  • 1993 HONDA ACCORD
  • 4 CYL
  • 150,000 MILES
The engine won't turn over. It wants to but doesn't seem to get that spark to fire the engine. Once I put jumper cables on it it turns right over and runs great. I've had the battery, plugs, alternator, and battery cables checked and been told they're ok.
Someone suggested it could be the cam sensor.
The check engine light does not come on at all.
It's like the jump is sending additional power to the engine and overriding what ever is causing it not to start.
Saturday, May 9th, 2009 AT 6:05 AM
MMPRINCE4000
  • 8,548 POSTS
When you say it won't turn over, do you mean it will not rotate or it will not start?
The fact that it will start with a jump, indicates a weak battery, loose battery connection.
Most autoparts stores will test charging system for free, battery AMPS, starter draw and alternator output. Try that first. Let us know the results.
Saturday, May 9th, 2009 AT 6:16 AM
PAULIE3
It won't start. I've had those items you mentioned tested and was told everything is ok.
It happens randomly. It'll start fine for three days and then when I try to start it after work say, it won't start without the jump.
Once the jumper cables are on the battery and I turn the ignition the car fires right up.
Saturday, May 9th, 2009 AT 6:54 AM
