times when I would go to start the car it would
crank over fine but wouldn't start, then after an attempt or two I was on my way. This would happen far and in between.
As time went on it started happening more often duh! Lol
The other day I went to start the car, it cranked
fine, it's getting fuel but wouldn't start after many attempts I gave up. I went to start it later and it started, so I let it run for a min. And then I cut it off.
The next day I went to start the car and the key stuck all the way forward I had to manually turn the key back so the starter disgaged ( it was cold outside) but the car started, sounded good and idled 3-4 min.
I went in the house to let it warm up, when I went outside again the car had cut off as I tried to start it the car just cranked again and again but wouldn't start. Help!
SPONSORED LINKS
Friday, January 2nd, 2009 AT 9:29 AM
