1993 Honda Accord No Radio AC Fan
F86ESABRE
Ok.Car would not start.Went on line for some answers.One suggestion was to hit the side of the drivers dashboard because it might be the fuel pump relay.Wow,that was it.It started right up.Here is the problem.Before finding this anwer one suggestion was to put in a jumper and check the check engine light for codes.Part of that procedure was to put a fuse in the "Back Up" empty space in the right side fuse box in the engine compartment.When I put the fuse in the Cd in the radio came out by itself.When I took the fuse out,the disc went back in.Well I put the fuse back in for the test and got know engine check lights.After I took the fuse out the problem started.No radio,AC,fan or cig lighter.They will not work.Everything else seems to work OK and no fuses are blown.Help,what did I do?????
Steve Jahn
Jun 30, 2007 at 1:52 PM
BRUCE HUNT
  • 3,754 POSTS
I am not sure, but there is a voltage regulator under the dash that could be been blown. Start by checking the fuses under the hood. The rap on the dash trick is only a short term fix. Pull out the EFI relay from under the dash. You will probably find the terminals are badly soldered and need to be redone. Take care of that and the rapping will not be needed.
Jul 2, 2007 at 1:20 AM
Suggested Repair
Check the under-hood fuses. Treat the dash tap as a temporary start fix: remove the EFI relay under the dash and resolder its poorly soldered terminals. Also consider that a voltage regulator under the dash may have failed.
Conversation Summary
A 1993 Honda Accord LX would not start until the driver-side dash was tapped, pointing to a fuel pump or EFI relay problem. While attempting a code check, a fuse was placed in the empty backup slot in the engine-compartment fuse box, which ejected the radio CD. After the fuse was removed, the radio, AC, blower fan, and cigarette lighter stopped working, although no fuses appeared blown. The expert advised checking the under-hood fuses, resoldering the EFI relay terminals, and considering a failed voltage regulator under the dash.
